UT99 + 8800 GTS = 40FPS
10 Dec 2006
Hi,
I have just installed an old classic game that I used to love playing. I have installed it and patched it to latest patch 436. Whats troubling me is that I'm getting only 40FPS on this system whereas on my other system I'm getting 80+ FPS and its a lower spec (Athlon XP2600+ - 9800 Pro).
Any ideas why I'm getting such poor framerate, when played online it seems jerky and awful. Tried in both D3D and OpenGL.
Any help would be appreciated!
thanks
I have tried tweaking things, one of which was the minimum desired framerate which is set to 80. Strange. Where do I get the update OGL?
Should be built right in?
When it scans for rendering modes, you need to check to make it show them all, then there should be one for OpenGL.
With my X1950XTX I have to run it in OpenGL, or it BSODs.
Yeah tried OGL thats already there same thing - sits @ 40FPS. Thought there might of been some updated version of those or something.
Any other ideas?
you need to get the new ogl driver for ut if you pm me on quaknet #.less or #ut1 my nick is d3MaTnU^
ill be able to get ut runing smoothly
