uTorrent and netgear router listen port probs
18 Oct 2002
Hi guys,
I've moved to a new house and have just got virgin internet installed and have been given a Netgear wgr624 v9 router. However, since moving I just can't get utorrent to connect to the listen port.
I have changed the port from the default to 65534, forwarded that port on the router, turned off the router's firewall, added my IP as a DMZ, turned off NAT filtering, UPnP and my software firewall (Eset smart security) and it won't bloody connect.
Does anybody have any more ideas?
B@
It's better to have NAT on also with utorrent there is an option to use upnp which if that is enabled on your router can sort your problem out.
Hi guys,
B@
Try a different port?
what is the admin login for the router? my mate is having trouble getting into his
even after a hard reset, virgin / password doesn't seem to work..
