Utterly bizarre problem - H80/PSU related
3 Jun 2005
This is a bit of a long one, so sorry for the incoming wall of text, but you need the whole story. I’ll try to keep it short:
Got a new H80 cooler. Installed it and started it up and it whined. I thought great, I’ve got a dodgy one. Just to make sure I hooked it up to my backup PSU out of the rig and it run perfect. A-ha, I thought, the backplate wasn’t on properly and was causing the noise. Re-installed everything with some adjustments to the backplate. Before dragging back to my desk I gave it a try on the backup PSU again and it was perfect. So I lug the PC back to my desk and wire everything up and start it up – whining sound is back! FFS what is that, I think! Well, it can’t be the H80 because I just tested that. So I go around stopping each system fan individually, but the whining continues and definitely appears to be coming from the H80. So I think to myself, pull the power on the H80 for a second and see what happens – I pull the power and the whining stops! It’s definitely the H80!
I go and get my backup PSU and have it sitting next to my rig. I pull the H80 power from my internal PSU and quickly swap it to my external PSU – silence! Literally the only thing that has changed is where it’s getting power from. I think to myself that it might be a dodgy modular lead, so I get a different one, but it still whines. Ok, I’ll plug it into a different socket on the PSU – it still whines. Hmm, maybe I’m overloading my 850w PSU, so I unplug all my HDDs – it still whines.
I’ve tried 3 different modular leads and 3 different sockets on the PSU, including the one which has been powering my HDDs for years.
I’m completely at a loss. :confused:
EDIT
It seems I've found the solution here:
http://forum.corsair.com/v3/showthread.php?t=107252
You might be able to plug the unit into a fan controller and reduce its voltage sufficiently to stop the noise. The problem here is that some fan controllers don't give out full power due to the way they are designed. Still 11v might be just fine for it.
Have the unbranded version, i have the same problem when its not getting enough volts, try testing the 12V line on your psu if you have a multimetre.
If you plug it into a motherboard fan controller make sure you set it to always full speed.
are you sure its not just the orientation that its in when its in your case?
ie the direction the pipes are pointing towards the rad
if I orient my h80 in a certain direction I think air gets trapped or something, and it makes a right loud noise
edit: oh nvm, seems like you sorted it
