UV Coolant
18 Feb 2009
Burton Upon Trent
I'm going to change my coolant and i want to get UV coolant and thinking of feser one because it is UV and has anti corrosive qualities. But i can't decide which colour if any one has any experience with it and could suggest a good colour then do so. also if you have any pics of ur setup with feser one then please post them. I really can't decied
I use the Blue UV (with clear / UV tubing) and blacklight UVs
Don't make the same mistake I did. I bought a bunch of UV cathodes and some UV fluid and then put it all together with UV resistant tubing without thinking about what that meant in practical terms :o
It's a lesson learned...
lol, also i like the blue, does anyone have any pictures of the red one?
Haha, unluck AWBbox!
And for an idea of what colour to get, check out the Watercooled Case Gallery. I suggest starting at the end (page 18) and working your way back, the original posts are from 6 years ago and are only really useful for a history of watercooling lesson :p
I personally use pink Feser... Not my ideal colour originally, just got it cos it was half price, but actually kinda like it now haha. Dont have any fancy UV shots, but here it is in day light :)
I was very disappointed with the red....it glows a faint orange colour. It looks good without any lighting effects (blood red) but stick any light around it and the orange comes through. I swapped it out for blue which glows a bit but still not enough IMO. I'm gonna use coloured tubing next time.
Green is by far the best I've used, it glows like a radioactive badger.
Orange uv fluid looks dull unlit, and doesnt glow that well under UV. So i went for orange UV tubing, which glows much better than the fluid.
Yea, Ive heard red coolant is pretty disapointing under UV lights, but it looks good under normal lighting. Think I just got this pic from google, not my PC
Alternatively you could just get red tubing?
Ahh, nice choice!! I was going to go for blue with orange anti kink coils when I was doing my build, but couldnt find blue Feser in stock anywhere and found the pink at half price instead haha.
I reckon blue and orange will look pretty nice though :)
