Deleted member 11679
Ok, I have heard a lot about people saying you 'need' a UV filter for lenses that are being used outside for the majority of their time/being used where the sun can really get them.
First off, is there a general opinion that having a UV filter on a lens will protect this and is in fact necessay?
Secondly, If I were to get a filter for my 70-200 F/4 L, which has a filter size of 67mm, I have a step down ring to make a filter size of 62mm work on this lens - which apparently makes it cheaper but is it also worth it? (I was given the step down ring by the guy I bought the lens off.)
Thirdly, what type or brand of filter is recommended? Obviously it needs a UV one, which is the one I am looking at...but I am struggling to find any Canon ones or do they not produce them? Is Hoya good?
So many questions! A little clarity to the situation would be muchos appreciated.
Tom
Tom
