UV Filters for protection
12 Jan 2006
UK
Hi All
Can anyone recommend a good make of UV filter for the front of a few lenses. Mine are all L lenses, so to be honest i want to protect the front as best as i can, as i go to mostly rallies and all it takes is a small stone to chip the front.
At the moment i have been using HOYA ones, which seem ok, but i dont want to be losing any IQ what so ever.
So whats the best make out there but still at a reasonable price.
i use a jessops uv on my bridge camera, but of course it's nowhere as expensive as your lenses!
if i had top kit, i'd use something like a top range hoya filter or cokin.
I have Hoya Super HMC Pro 1s one all my L lenses. Haven't noticed any lose oc IQ and give the added piece of mind that there is some protection. Although it can be expensive to replace a filter if it gets damaged.
NorthstaNder: You will need to star out that High Street competitor.
Blackvault
I don't bother, on my 70-300 the most expensive hoya threw the AF out, and as I now have lens hoods on everything I don't bother.
If it doesn't do an effect, I aint bothered :p
I use Hoya Digital Pro or B+W on all my L. To be honest, if you compare the two together side by side, B+W wins. As for results from actually taking photos. I see no diff.
Jessops' filters are essentially Hoya but the lower end range.
Kenko is Hoya - it's the Asia/Japan branding where as Hoya is international. Save a few quid and get Kenko.
I would probably focus on what you need e.g. super thin to avoid vinyetting on super wide, cokin style for landscapes, etc rather than 'pure' optics.
They cause flare in high contrast situations. I only use them when I think there is a chance of damage to the lens, such as shooting near the sea, or when its raining. Most of the time I protect the lens with a lens hood. It protects the lens, increases contrast and reduces flare. Much more useful than a UV filter
Plenty of examples of internal reflections caused by UV filters if you search. This was the pic that convinced me to get rid of them
I don't notice that problem personally but that's not to say it doesn't happen. UV is impt during the day as it does cut out glare on a sunny day that's noticable on the end result. Polariser of course is better on a sunny day.
