UV Things
the cost of UV paint will most likely be around the same price as buying some UV fans. plus the fans are a lot less hassle
If you're planning on painting your fan blades then one possible problem willl be with them ending up out of balance afterwards if the paint is at all uneven, generating more noise.
I doubt afew drops of paint will destroy the balence of the fan to such an extent
Small tubs of UV reactive paint should only be a few quid, some accents here and there should be too hard.
you could also get a molex UV kit, replaces standard molex's with UV reactive ones.
Yeah you could do that and get some UV reactive cables for sata/ide and what have you.
Might be better off with a blue cold cathode or any colour really. As i think uv lights work best when one has done a water cooling rig and used uv reactive coolant.
