I'm installing it the same way I've always doneConrad11 said:Are you installing it correctly. It's a common mistake, make sure you read ALL the instructions and follow them correctly.
Grabbed it also... CheersReggie said:glad it worked. will leave it on me webspace for a bit , see if anyone else needs it as it was a bitch to find one that worked![]()
