V Brake Adjustment Screw
18 Oct 2002
7th Level of Hell...
I seem to have "lost" one of the spring adjustment screw for my MTB V Brake.... Is this a specific type of screw someone can point me in the direction to purchase (my Google skills are failing me) or can I use any kind of screw??
Its the screw you turn to increase the tension of the spring so that it pulls the brake shoes away from the rim. At the moment, when I press the brake, one of the shoes remains in contact with the rim causing a constant braking action...
Ta :)
Not a clue... Its quite a wide thread thats on it.... I'm guessing, if its a non special screw, I can take one to my local hardware shop and get one?
Tbh I can't see why a bolt with the same thread won't suffice until you can source a grub screw.
It's serving quite a simple purpose, to realign the arm of the caliper so isn't bearing any load or subject to any force.
Your LBS will probably have a box full of them.
