running a E6850 @ 3.9 with 1.520 voltage at idle!then when running orthos cpu test the voltage reading drops to 1.480 at 100% load in cpu-z. then bsod happens.. is this down to v droop or v drop.
nothing bad happened but i got to 3.8ghz which required an insane amount of volts, 1.63v or something, if i no one said i guess it might of shortened the cpu life significantly or something. Theres also more chance of spikes in the current which could foo-bar the cpu i guess
