V10 Coolermaster Installation
21 Jul 2011
Has anyone installed one of these? Any tips going into it? I'm just about to start doing mine but couldnt find any guides online.
Sounds like you are doing it right, I'm pretty sure step 6 is something about a blood sacrifice :D
Hah, is that Hex of Order of the badgers?
Yeah it was trying to pull it out of the stupid poly wrap it was wedged in and my finger slipped right along the vents. Losing your thumb really makes tightening screws hard :P
I'm afraid I know not of this Order of the Badgers, however it sounds amazing!
Ah okay :) Nah I play online with a Hex and Sharpe. Thought you were of that Hex fame.
If I don't make it through the next part of this build I want you to have my thumb.
It's fairly easy to be honest, hardest bit is fitting the power cables around it.
if you need any guidance with any bit let me know, I have re fitted mine about 4 or 5 times now.
Thanks JAG, in truth you are right. The fitting of it was fairly straight forward and the back plate was actually a lot easier than I was anticipating. I'm very thankful for my HAF X case, gives me plenty of room. And there is only two leads from the V10 so the cable management has been easy.
Ah so you have a cpu mount hole then?
I'm thinking of cutting one in my case that would make everything a lot easier for me. that way you can plug things in beforehand then install it, whereas I had to install out of the case then plug everything in.
Yeah I have a nice hole in the back plate, almost not big enough but I just managed to tighten the screws. I don't get why they don't make that hole a proper size.
Mine hopefully will be made to measure, just got to find something to line the edges with, to make it look smart, and find spare time to do it in.
Still even if it is tight still easier then none at all
