26 Jun 2006 at 21:17 #1 bigstevex bigstevex Associate Joined 30 Nov 2005 Posts 149 Will the leads reach?? Especially the 2 PCI-E Ones for my 2X 7800gtx's Cheers!
27 Jun 2006 at 16:16 #2 senorstealth senorstealth Permabanned Joined 16 May 2006 Posts 265 Location down the pub The PCI-e leads are 58cm long, the molex are 70cm, can't tell you the lengths of the others as their all in my system. Hope that helps
28 Jun 2006 at 12:40 #3 bigstevex bigstevex Associate OP Joined 30 Nov 2005 Posts 149 I think they should fit, i wonder if you can get PCI-E extensions?? I got the V2000 plus in the end!
28 Jun 2006 at 12:41 #4 Yewen Yewen Soldato Joined 9 Nov 2003 Posts 17,699 Location Leeds Yes you can. And OcUK stock a surge protector that would serve the same purpose.
28 Jun 2006 at 12:51 #5 hp7909 hp7909 Soldato Joined 8 Jun 2003 Posts 4,961 Location NBO This might help
28 Jun 2006 at 12:58 #6 Yewen Yewen Soldato Joined 9 Nov 2003 Posts 17,699 Location Leeds hp7909 said: This might help Click to expand... Lost me.
28 Jun 2006 at 13:24 #7 hp7909 hp7909 Soldato Joined 8 Jun 2003 Posts 4,961 Location NBO Yewen said: Lost me. Click to expand... Lengths
28 Jun 2006 at 13:29 #8 Yewen Yewen Soldato Joined 9 Nov 2003 Posts 17,699 Location Leeds Ahh! Sorry thought you were on about the extension cables!
28 Jun 2006 at 19:02 #9 bigstevex bigstevex Associate OP Joined 30 Nov 2005 Posts 149 those things oc sell are £12 each lol, i'll see if they fit first, case is 1-3 days it says! Thanks anyway for the info!!
28 Jun 2006 at 19:28 #10 Yewen Yewen Soldato Joined 9 Nov 2003 Posts 17,699 Location Leeds You can get just extensions from elswhere.
