VA 4k 27"-32" Monitor
10 Sep 2017
Hi, i need some recommendations on what monitor fits my criteria.
I've done some research and come to the conclusion that 4k with a VA Panel between the range of 27-32 inches is the best for media consumption and regular browsing e.g. Movies/Series & browsing/general stuff.
What monitors would you recommend? My budget is around £1000 max but preferably lower.
I sit around 1ft away from my screen? I have bad eyesight and don't want to wear my glasses while on the computer but that's another issue and just relates to me buying a bigger screen and having to move the screen back on my desk. Currently on a 24inch which is really bad and has probably done a lot of damage to my eyes.
Thanks!
