- 15 Oct 2015
I'm looking to get a vacuum sealer to make it tidier and easier to put things away in the freezer. Anyone who can recommend a good one? Price range up to £50.
I bought one the other week. I did a fair amount of research into the various ones, both from the ultra cheap up to FoodSaver etc. In the end I settled for the greatly named Aicok because it has a good warrenty, works with liquids and has a pulse button unlike a lot of them to control the amount of air taken out. I bought some cheap rolls to use in it and the combo seems to work fine.
Both come in under your budget by 2p too at £49.98![]()
Need to order a few other things from the rain forrest as well.
Be interesting to know how you find it. I've 16kg of chicken and turkey breasts from MuscleFood due on Friday that's going to put it to the test somewhat!
That is a bit of a deal breaker, if you bulk prepare currys, lasagne meat mix, stock, etc., and then cannot, in one shot, evacuate the bag and put into the freezer,Pro tip that I read for vacuum sealers in general: sometimes it's easier to put liquidy things in the freezer for a little while before you try and vacuum seal them. If they're slightly frozen it makes them a bit more malleable.
Ok - it is true the liquid is generally thickened too, and can, I imagine, support the sealer a few inches above bag lip.Just can vacuum pack moist... hit the seal button before the liquid goes flowing into the suction area
where do you get your bags ? (less resiliant freezer grade ones, usually <£2 for 80@20x30cm)I much prefer to have a range of ready made (sealed on three sides) bags
