Valheim Reshade settings
3 Jan 2018
Brighton
So last night I installed the HD Overhaul texture pack and it makes a huge difference! I installed reshade to try some presets but they're all so... Dark or over saturated.
I tried setting up my own and got something I liked - then realised the UI looked absolutely disgusting, especially the build menus. Had to disable some of the FX and basically left with a bit of extra brightness and colour.
Anyone else using Reshade in Valheim and got some presets that don't make the UI look gross?
