Value my car please & also help with a little problem! Possibly spec me...
22 Jul 2006
Hi Guys,
Just taking from the Audi thread as think it may get a little lost in there, can you give me a rough idea on how much car is worth please:
Audi A4 S-Line
56 reg
Auto
87k miles
2.0 tdi 140
Pretty standard spec no leather or nav.
Basically since getting the Qashqai as the family car mine only did around 10k miles last year May - May.
If possible would like to be able to swap into something a little more exciting.
The problem is we will be spending a few k in the coming months on the house and with the little one having arrived 10 weeks ago priorities have changed a little so car priorities are well low on the list.
Just wondering if there are any cars I could likely do a straight swap with mine? What would you consider?
30mpg minimum
Ideally no older than current car
Petrol
Thanks
Octavia vRS? Nice big boot and goes when you put your foot down? Not sure if you'd be able to do a straight swap though :(
Thanks and will have a look, all depends on the value of my car.
Regarding boot space, not so much a problem due to having the other family car. Just can't be a 2 seater though!!
Had in my head around £5,500 - £6k at a push.
What are peoples thoughts on a golf GTI around these prices?!
Hmm thanks for the suggestions, may look at the 3.2 DSG A4, much to look out for in them?
I notice on the GTI's the mileage is around 110k + in the price range, assuming fully serviced correctly can much go wrong?
