Value PC System (OC tech required)
1 Oct 2008
Designing Buildings
Hi,
I'm looking at a pc for a friend with a limited budget (under £600) and have seen a pc which fits the bill 'Primo Edge" Intel Core 2 Quad Q6600 2.40GHz SILENT DDR2 System' My friend is looking for a pre built system but the ones OC offer dont have an option to include a wifi card. I know buying a separate wifi card is no hassle or transferring it from his old pc would be ok but i was wondering if someone (like myself) fitted a wifi card would it invalidate the 1yr Onsite Collect & Return Warranty? if it does could this be fitted on request before leaving OCuk?
Best to phone the shop regarding the warranty if an internal wifi card is fitted but an external USB wireless adapter would not invalidate any warranty.
Heatsink - "Primo Edge" Intel Core 2 Quad Q6600 2.40GHz SILENT DDR2 System
All, could you kindly inform me what heatsink is used in the "Primo Edge" Intel Core 2 Quad Q6600 2.40GHz SILENT DDR2 System
