actually.. just found it.. £170 seems a bit expensive for a b-grade especially when the Valves ones are less than £140 new
You can get them from HTC direct, but they don't supply mounts with them. As Overclockers sell base stations (even if they are B grade) I won't supply a link or price.
Vive 2.0 base stations are identical to the Valve ones, apart from the lack of a mounting bracket.
Is there any difference functionally?You can get GEN1 Used they work with Index
