Vandal switches help
17 Sep 2008
Hello.
I have fitted custom LED vandal power and reset button in my lian li case. These have replaced the stock power and reset switches.
However, I'm not sure if I should keep the stock HD and power activity leds.
It seems now I have too many leads to attach to the pins on the motherboard. Shall I just not bother with the HD and power activity leds?
My aim is to have the custom led vandal power and reset buttons lit up when the pc is on.
Do you want the hard drive and power lights?
How can you have too many leads?
Im assuming you have the power button and power light both going to the anti-vandal switch. If you also want another led, then splice it into the same cable that runs onto the header. I would put the hard drive activity light on the vandal switch for the reset. Would look good.
