Vanilla android phones / custom ROMs and banking apps
18 Oct 2002
Looking at new budget phones, and hoping to find something that's plain vanilla Android or close to it, and avoid bloatware.
Any suggestions on brands that meet that criteria? I think the Motorola Gxx phones are vanilla android.
Currently a Xiaomi user, and have been for a while.
Alternatively, I was thinking of custom ROMs for my Xiaomi, but I gather banking apps do not work, or at least require quite a bit of work to make them work when you have a custom ROM.
Is that correct?
Thanks.
Correct, unlocking the bootloader and installing a custom ROM will break Play Integrity (SafetyNet successor) which banking apps do rely on. There is a Magisk module that can bypass this however, but it's very much cat and mouse as Google will work to fix this, then you'll need to wait for a new solution.
Moto is close to stock but their update schedule is a mess and unreliable. HMD/Nokia are also pretty much stock and I think their update schedule is a little better than Moto.
I'm guessing the Pixel phones are out of your budget? You can sometimes find the a series or even the non Pro version on a good deal.
I had a Nokia/HMD phone a few years back and it was brilliant. I'm out of the loop so not sure if they are still doing good phones. Wife has a Motorola a few years old and it's been average. Bit buggy at times.
I'm thinking Pixel next but I just cba to spend more than 300 on a phone.
Yeah, I got the impression it was like that, which I definitely do not want the hassle with given how damn important banking apps are to me.
Interesting to know that, thanks.
Yeah, I think they are beyond my budget really. I'm a £200 max kinda budget, for something I might drop on the floor/loose/drop in the toilet/etc :D
I'd kinda forgotten the bloomin obvious Google phones being the obviously more pure flavour of android......saying that.....do Pixel phones actually let you uninstall some of the google crap I wouldn't want, I wonder.
I'll take a look at Nokia.
You can buy renewed Google pixel 7 phones for less than £300.
I was thinking of getting a pixel 7 pro until I read that they don't have brilliant modems and can suffer from poor signal.
I moved from a Motorola G7 Power to a Pixel 7a. I only moved as I wanted NFC. I wouldn't recommend the 7a due to the poor connection. Battery life was poor too, but seems to be better. I'll stick with it for a while, but I'm tempted to trade it in and see what's available for about £250.
