Considering buying one of these, have no case lights so dont see it necessary to get one of the ones with that function.
BUT
It only on its lowest setting puts the voltage to 7v, 5 is possible and is what I am currently running my zalman gpu cooler and front case fan.
Am I gonna hear any noise difference between the 5 and 7v or does anyone else have any suggestions to other controllers.
PC can be as loud as it likes during the day so I will put the fans up then, and then I leave it on overnight downloading and sleep in the same room so I would like to turn the fans down to low as safely possible
BUT
