Vantec Spectrum Graphic Card Cooler
2 May 2004
Hi,
When I get my motherboard back from being replaced I'm going to redo my airflow - my current airflow setup (http://forums.overclockers.co.uk/showthread.php?t=17634788) stops me from using dual channel on my RAM.
I'm probably going to move the fan to the 'bottom' of the heatsink so it's blowing through the CPU and into the PSU, but the slight problem with that is that the fan will be drawing some of/a lot of the hot air off the graphic card and probably heating the CPU up a bit more.
I've been looking around and have found this: http://www.overclockers.co.uk/acatalog/Vantec_System_Coolers.html#aFG_2d004_2dVA which seems quite good.
I just wondered how well these perform, how noisy they are and if they're actually worth it?
Thanks,
Craig.
