So my current setup is;
i7 2600k @4Ghz
16GB 2133 ram
Twin Frzr II GTX 580
PCIe 2.0 mobo
I only game at 1080p and that isn't likely to change for a long time.
I'm looking at upgrading my GPU in a few weeks because the fans on my GTX 580 have died and it seems to be getting sluggish.
Atm I'm either going for 290 or 290X vapor-X cards I've looked a bunch of reviews but it's hard to gauge the % increase of the 290x over the 290 because all the reviewers have different test setups, so if anyone knows that would be nice
? Also it's case of how much is enough for 1080p? With the increasing number of 1440p+ setups I would imagine eventually you won't need a top tier card for 1080p.
Anyway thanks
i7 2600k @4Ghz
16GB 2133 ram
PCIe 2.0 mobo
Anyway thanks
