Vapor-x or not?
Hi, i'm thinking about buying 2 x vapor-x HD 5870s for crossfire. Would it be better to wait for a vapor-x HD 5970?
depends if you can fit the 5970 in your case, check some reviews for the 5870 in crossfire against the 5970..
math
Doesn't the 5970 have some sort of vapour-chamber cooling system anyway? I thought it was mentioned on the ATI slides...
The Vapour-X usually win on quietness but as mentioned before they don't tend to vent hot air very well. I suppose its down to preference; if you are buying such leet kit your case must have great airflow anyway.
