Im looking to get a sapphire hd 5870 vapor-x but is it really worth the extra £35-£40 to have the Vapor-x cooler and overclocks?
and if you find it to hot, which it should be fine, then change the stock fan
oh i didnt know there were 2 different versions of it. im not going for a 5850 because i can afford a 5870
ill see if i can get my hands on a v1 of the sapphire and overclock it with msi afterburner. though im thinking of getting the Asus version...
edit: dont have the money for watercooling!![]()
when that Asus ATI Radeon HD 5850 clocked @5870 speeds will do a exellent job. just think you will save loads
Yes it's worth it because it's quieter.
thats what i was thinking...
also i want to get a 5870 because... it will be even more kickass than a 5850!![]()
edit: also its cooler?
Not sure what I'm going to buy I'm thinking of 5850 because . . .And dont listen to people saying get a 5850 and clock it because it has less stream processors get a 5870 and clock that instead!
Plus I'll save £130 buying the 5850 as opposed to the 5870 Vapor-X (V2) which hardly clocks anyway.Source
- For anyone that does not overclock there is a large difference between both cards performance. The 5870 is >20% faster.
- At the same clock speeds the 5870 is about 5% faster overall. In shader intensive tests this increases to ~10%, which is to be expected because the 5850 has 10% less shader cores.
- When both cards are overclcoked to the max there remains a ~5% advantage to the 5870.
- For anyone who overclocks, the 5850 offers much better value. 5% more performance currently costs 50% more money, and unless you are either a hardcore bencher, or have money to throw away it is really not worth it.
- Core clocks on both cards reached similar levels although the 5850 required slightlly less volts. This may be due to the 5850 having 10% less shaders.
- The memory on the 5870 overclocked to 1300 vs 1200 for the 5850. This may be pure luck, but it may also be that ATI supply lower voltage to memory IC's, regulation is poorer, or the IC's themselves are not as good.
- An overclocked 5850 can easily beat a stock 5870
- Some cards will overclock different than others so mileage may vary.
