Variable Compression Engine
Well the Jalopnik headline is
The World's-First Variable Compression Ratio Engine Could Kill Diesel Forever
A 14/1 compression ratio doesn't help the engine at all load and RPM ranges, variable will, so yes, it could feasibly beat a diesel once it's dialed in properly and designed for efficiency and not both power and efficiency
