I was wondering if it is possible to cut the power wire going to a fan, add in a v. resistor, and use that to control the fan speed? Is there any reason why this shouldn't work?
The fans in my case are on 4 pin-molex cables, so finding a controller is proving tricky.
Getting hold of a few v.resistors shoudln't be hard, and will mean that I can turn the fans down when only doing simple taks, and then turn them up again when they're in need.
