Variables in Stored Procedures...
18 Oct 2002
The land of milk & beans
Admittedly my SQL is a bit rusty when deviating from the basics, but this shouldn't be as difficult as it's turning out to be.
Anyway, put simply the problem is i need to run a query, and return the values into declared variables, the below is just returning null for both entries :(
Any help appreciated!
DECLARE @AccountID int
DECLARE @BroadcastID int
DECLARE @CampaignID int
SET @BroadcastID = 1
SELECT AccountID, CampaignID FROM Broadcasts WHERE BroadcastID = @BroadcastID
SELECT @AccountID AS AccountID
SELECT @CampaignID AS CampaignID
Dammit, the OcUK effect strikes again - post something after trying for a couple of hours, then solve it 10 minutes later :)
Here's what i needed to do if anyone ever runs into the same problem...
SELECT @AccountID = AccountID, @CampaignID = CampaignID FROM Broadcasts WHERE BroadcastID = @BroadcastID
SELECT @AccountID, @CampaignID
