Vario problem.
21 Oct 2003
Back with a Vengeance.
hopefully some of the more tech minded members may be able to help me here.
i installed some software which i've since removed from the device.
the problem is i've tried to install a newer version of the same software but the installation fails every time.
the problem definitely doesn't lie with the software as i've already installed it on a Vario 1 and 2 so all i can think of is the earlier version i'd installed has left some files behind and this is preventing the newer version from installing.
is there any way i can put my Vario back the way it was from new, or maybe there's a freeware prog that can fully remover any leftover files?
i haven't done a hard reset yet as i'm not exactly sure what this does to the device.
any help appreciated.
thanks for reading.
