- 1 May 2007
I have recently put my first computer together and its all going great....however....
The temp reading in the BIOS is worryingly high. It gets up to 60c! The strange thing is that SpeedFan has idle temps around 35c.
I have a E4300 on a Gigabyte DS3 and am using the stock cooler.
No overclock.
When i apply slight pressure to a specific corner of the heatsink the temps in the BIOS can go down to 30c, suggesting its not seated properly. I have attempted to reseat several times with the same result each time.
Another odd thing is when the case is on its side the BIOS temps are 50c but when i stand it up they can go up sometimes to 70+!!!! Once again this suggests the heatsink is not seated correctly, however the trend is not repeated when using SpeedFan to monitor the temps
I cant get CoreTemp or TAT working not sure if they are compatible with Vista 64????
If the SpeedFan temps are true then its ok, but if the BIOS ones are then something is seriously wrong. Which should i trust?
cheers
No overclock.
cheers
