Caporegime
- 1 Dec 2010
- Welling, London
Ok, how much is the original price of an product if you have to pay £500 inc VAT?
Thank you for settling an argument. I will now be informing my argumentative brother that he has been paying too much tax on his private jobs.
Depends on the VAT rate which applies to the goods or services in question.
price /1.x
with x being the rate of vat.
price /1.x
^^^ this, where, in the UK, x could commonly be .2, .05 or 0
Yes, exactly that.Is he doing 20% of the total price? 20% of £500 is £100 VAT so £400 cost before VAT. That's a common mistake.
Except if you're using something like a Margin Scheme (e.g. on the purchase and sale of second hand goods).
VAT is one of those things that looks simple from afar, but the closer you get to the detail the more it's better to back away. Slowly. Then turn and run away.
Make sure you get your commission if you are right. Could offset all of your recent identity fraud lossesYes, exactly that.
Good self awarenessI said he should just charge a price and forget the vat completely.
probably not the best advice tbh, but then I’m no accountant.
He can do a correction to claim back the extra VAT he's given to hmrc in error , though depending on how much it all totals to, he might have to make them aware (I can't remember the exact figure off the top of my head but it's in the thousands so if it's only a few hundred then he can do the correction without having to also notify them)I said he should just charge a price and forget the vat completely.
