10 Jun 2009 at 21:20 #1 M0T M0T Soldato Joined 23 Aug 2003 Posts 4,582 Location House My mums friend has an 02 plate corsa that has some kind of fault, he asked me if I can plug my laptop into it. I have an OBD2 cable, does anyone know of any free software I can use to read the codes from the car? Cheers
10 Jun 2009 at 21:39 #2 malfunkshun malfunkshun Soldato Joined 20 Aug 2003 Posts 6,703 Location Pembrokeshire Can you use Linux cli?
10 Jun 2009 at 21:41 #3 Justintime Justintime Soldato Joined 24 Jul 2006 Posts 8,876 Location Hoddesdon, London, UK Let it die a natural death p)
10 Jun 2009 at 21:45 #4 leaskovski leaskovski Soldato Joined 22 Oct 2004 Posts 9,086 Location Berkland See this thread here.... http://www.corsa-c.co.uk/forum/showthread.php?t=134139 Turn the electrics on with your foot on the throttle and brake pedals (its explains in the thread above http://www.corsa-c.co.uk/forum/showpost.php?p=2720869&postcount=9) then count the flashes of the ecu light to get your fault codes. It works, ive done it on mine to find out I had to replace the crankshaft sensor.
10 Jun 2009 at 22:01 #5 Tee Hee Johnson Tee Hee Johnson Soldato Joined 30 May 2007 Posts 5,014 Location Glasgow, Scotland /\ It does work... tried it on mine a while back! Didnt have any faults tho
