Ive got a string variable that holds the name of an object.
What i want to do is check to see if that object exists before creating it
Normally you'd do
If objWhatever is nothing then
objWhatever = new blahblah
endif
what i want to do is use the contents of the string as the object name and do the check on that.
Any hope of doing this in VB.net?
Normally you'd do
endif
