VB.NET books/tutorials
13 Jan 2007
Belfast,Northern Ireland
Been put on a project using VB.NET and having never used it before its seeming quite daunting right about now!
Anyone relatively experienced with it can they suggest some books/tutorials in order to get to grips with the language as fast as humanly possible.
I'm a comp sci grad but not the most talented programmer!
I thought it was only myself in Belfast who used VB.NET!
I have used it on projects that I 'inherited' from other people and just picked up stuff by looking at other folks code. Normally I just refer to MSDN and look at the samples they have.
Is there any reason why you aren't using c#? Most folk seem to say to use it as opposed to VB.NET. I'm not totally sure why to be honest.
I find C# much more understandable and easier to write, it's similar to other languages so if you have previous programming experience you can pick it up very quickly.
If i had to choose between VB.Net and C# I'd go with the latter every time.
But if someone has come from the VB background i see why VB.Net would appeal to them.
Actually in Toronto at the moment. The project is similar to an old one the company did so essentially they want to re-use as much as possible. Much like has been said I know c#.net and would find it far easier to grasp as a newbie....vb.net, not so much!
