VB script
Man of Honour
17 Nov 2003
Southampton, UK
Guys, I need help with a VB script in AD, I need it to be able to change the path of the home directory within the user profile. I need to change the server name but not the share name, so \\tango\share1$ will become \\alpha\share1$.
Any ideas?
Cheers
Burnsy
Edit: the script needs to only target one AD OU and all the users in that OU
Can't you just select all the users in that OU and then change the home directory from properties?
Found this on the MS site:
Code:
Set objUser = GetObject _
    ("LDAP://cn=MyerKen,ou=Management,dc=NA,dc=fabrikam,dc=com")
strCurrentProfilePath = objUser.Get("profilePath")
intStringLen = Len(strCurrentProfilePath)
intStringRemains = intStringLen - 11
strRemains = Mid(strCurrentProfilePath, 12, intStringRemains)
strNewProfilePath = "\\fabrikam" & strRemains
objUser.Put "profilePath", strNewProfilePath
objUser.SetInfo
That should do fine, just needs tweaking.
Sure thing. Microsoft Script Repositry, 'tis the way forward. Link :)
Drill down to:
Script Repository > Active Directory > User Accounts > Configuring User Accounts
