Hi all,
I'm after a little help. I'd like to get a script together that allows the user to quickly search through large Word documents for 1 or maybe more key words and will return possibly a form back listing how many of said keywords were found.
For example I open up a technical document, run the script which prompts me with a dialog box/form where I input 1 or more keywords and hit go/find. It does it's stuff and then displays a different form detailing the words searched for and the amount of times they were found.
I could just use the find function, but that is rather limiting.
Any help, or good sources to look at would be really appreciated.
Cheers.
Cheers.
