Vb6 Help!:)
8 Oct 2003
Glasgow
hi im looking for a function do to the following
(12345 example1), i want to remove example1 and keep the numeric 12345, however 12345 can change in length ie 123/12 i have tried (left x) but its not good enuff due to the chaning sizes of the left side of my string.
Cheers for the help kevin!
Not the most elegant example:-
Code:
Dim splitChar As String
Dim textToSplit As String
Dim resultText As String
splitChar = " "
textToSplit = Text1.Text
resultText = Trim(Mid(textToSplit, 1, InStr(textToSplit, splitChar)))
Text2.Text = resultText
You can also do it like this:-
Code:
Dim splitArr
Dim result As String
splitArr = Split("12345 Test", " ")
result = splitArr(0)
Text2.Text = result
