VB6 triggering AutoCAD installer
26 Feb 2004
China (Qinhuangdao)
Not sure if anyone can help with this rather weird problem. I have AutoCAD 2007 installed on my laptop. I also have VB6 installed. I tried to run an application that has been written in VB6, and at a certain point, it tries to run the AutoCAD installer, and asks for the CD.
So I got hold of the code, opened it up in VB6, and it does the same thing. Then I tried viewing the form layout in VB6, and immediately it tries to run the AutoCAD installer. I don't know what it's trying to install. The program doesn't use AutoCAD at all.
I think this is quite a rare problem as I can't find any solution from Googling. However, I did find this link, but I have to pay to view it : http://www.experts-exchange.com/Programming/Languages/Visual_Basic/Q_23090722.html
I've checked all the file associations, and they are all set to VB6.
Any guesses to what might be causing this?
I'm pretty sure it's a windows installer problem. Something has replaced a file and it's trying to recover the correct version from the AutoCAD installation files when VB6 loads.
The answer from EE was:
I have a similar problem. Whenever I launch VB6, the Autocad installer keeps trying to startup till VB6 is fully loaded. I've fixed it in the past by re-installing Autocad, but it's a pain, and then it comes back!
