VBA Access
12 Mar 2006
N.E England
hey all im doing some VBA programming at home i need to make as one of the excercises a form which will accept a word and it will have a modified word box it needs to have command buttons which when clicked will show the original word, the word in All upper case and then all lower case ive made the form i just need the code is there any websites out there etc which would be able to help me a bit thanks for any help.
Tom|Nbk said:
this is from my workbook i can scan the other pages if needs be im doing the top one
You can pretty much use the code I posted, but you'll have to change it slightly and paste in the right place in your code. As it's an exercise, you should work out the rest for yourself.
