VBA Code for Close
22 Apr 2003
Newcastle
I have a user form made via Excel and need to add a button to close the form.
Does anyone know what code I should be using?
Thanks
Paul
Well, rather than close the form, you could add a bit of code that hides it (therefore allowing you to show it at a later stage).
The VBA code is pretty straight forward.
[sheetname].visible=xlSheetHidden
Ok, That works however i have one more problem
I have text boxes that allow the user to type in numbers and descriptions. I need this data to be copied to seperate cells on my worksheet when the OK button is clicked.
Anyone have any ideas?
Thanks
Paul
