VBA help.
Man of Honour
30 Oct 2003
Essex
I am a little stuck with some vba... what I want to achieve is that when a user clicks "save as" a dropdown list appears allowing the selection of one of 3 or so values, once a value is selected a text box will then appear asking the user to type a value, these values will then be concatenated and added to the footer of the document.
so far I have:
Code:
Public Sub FileSaveAs()
   Dim MyText As String
   strData = InputBox("value here....")
   With ActiveDocument.Sections(1)
   .Footers(wdHeaderFooterPrimary).Range.Text = strData
   End With
   MsgBox ("The footer has been updated")
ActiveDocument.Save
End Sub
Now this does half the task and allows me to input some data into a text box, click ok and the footer is updated however having not used vba in as long as I can remember the dropdown list is evading me...
Any help much appreciated.
I dont think you can add a combobox to to an input box, you will probably have to create a custom form for that type of functionality.
When you initialize your custom form you can easily add items to it by using:
Code:
With ComboBox1
   .AddItem "Item 1"
   .AddItem "Item 2"
   .AddItem "Item 3"
   .AddItem "The best item!"
End With
Yea I saw that there was a way of adding values to combo boxes and dropdown boxes in the object model however the document does not have a combo box in it to add values. What I want is to display a combo box when the vba runs on save, the value selected will then be stored in a variable in the code. Once the code has then run it will then be used to update a footer.
