VBA Help
6 Jun 2011
Hi guys,
I'm trying to write my first VBA script as failing miserably. Essentially I am trying to put a sheet of data in various groups depending on some values in the cells.
I guess the first question would be is there an easier way of doing this?
If not then what is the easiest way to find the last row on the sheet? I see a lot of suggestions using End(xlUp) or something like that but I cannot seem to get this to work!
lots of ways none of them perfect but the best option imo is:
range.find("*")
have a look here for a decent explanation how it works.
http://www.rondebruin.nl/win/s9/win005.htm
Best to create a wrapper function and pass the range you want to find the lastrow for as a parameter:
i.e.
Public Function MyLastRow(byVal rangeToSearch as range) as long
Dim result as long
om error goto eH
result = rangeToSearch.FInd("*"....more parameters)
MyLastRow = result
on error goto 0
exit function
eh:
''error handling here
End Function
As a tip you can also loop for all the sheets in your workbook like this
Public Sub MyLoop()
Dim ws as worksheet
For each ws in thisworkbook.sheets
''do whatever you need to do here to group them
Next ws
End Sub
Ok I'm making progress :)
Could someone tell me if this is syntactically correct please?
Code:
If Cells(5, k).Value = "" Or Cells(5, k).Value + total < 75 Then
