This is a bit of a long-winded explanation. Basically, we have several users using the same database for projects. If they have updated their database while on a project, I want to compare the databases side-by-side to see which tables have been the last to be modified, so I can tell that table needs to be copied to a 'Master' database.
However, what I have noticed using the OpenSchema command, is the 'Date Modified' is not actually when the table has been updated, but when the table has been redesigned in some way.
So, in my software, I need to store the actual date updated somewhere in the database. When I open the database in MS Access, I can right-click on the table, and it will display the following:
Date Created
Date Modified
Description
So, rather than adding another field to the table, like "Date Updated", I wanted to write the actual date updated in the Description part of the table.
I've manually entered a date in the Description, e.g. "2023/12/10" and I can read this back in my software using Master.OpenSchema(adSchemaTables, Array(Empty, Empty, Empty, "Table")). However, this is read-only. And I cannot seem to work out to write to this part of the table.
I really don't want to add another field for every record of the database, when I only need to store one date. So does anyone know how to write to the description part of the table?
Date Created
Date Modified
Description
