VBS script help
18 Oct 2002
Southend-on-Sea
I'm trying to create a script that will email the results of a mysql query using VBS. I don't have any experience of VBS but have found a script online that will do what I want. However, I only want the script to email results if rows are actually returned. If the query returns zero rows then I want the script to end before emailing anything. Here is the script I'm using (some details redacted for security), can anyone advise on how I can stop the mail sending if zero rows are returned.
Thanks.
Code:
option explicit
dim dbHost, dbName, dbUser, dbPass, outputFile, email, emailFrom, subj, body, smtp, smtpPort, sqlstr
' Configuration '
dbHost = "localhost"
dbName = "xxxx"
dbUser = "xxxx"
dbPass = "xxxx"
outputFile = "c:\inetpub\wwwroot\dev\bs\batch\Scheduled Works.csv"
email = "xxxx"
emailFrom = "xxxx"
  subj = "Scheduled Works"
  body = "Body text"
  smtp = "xxxx"
  smtpPort = 25
sqlStr = "SELECT tasks.task_ref AS REF, clients.client_name AS CLIENT, tasks.task_address AS ADDRESS, tasks.task_description AS DESCRIPTION, DATE_FORMAT(tasks.task_next_date,'%d/%m/%Y') AS DUE_DATE FROM tasks, clients WHERE tasks.task_client = clients.client_ref AND DATEDIFF (tasks.task_next_date, CURRENT_DATE) <= 14;"  ' SQL statement you wish to execute
' End Configuration '
dim fso, conn
'Create filesystem object
set fso = CreateObject("Scripting.FileSystemObject")
'Database connection info
set Conn = CreateObject("ADODB.connection")
Conn.ConnectionTimeout = 30
Conn.CommandTimeout = 30
conn.open("DRIVER={MySQL ODBC 3.51 Driver}; SERVER=" & dbHost & ";PORT=3306;DATABASE=" & dbName & "; UID=" & dbUser & "; PASSWORD=" & dbPass & "; OPTION=3")
' Subprocedure to generate data.  Two parameters:
'   1. fPath=where to create the file
'   2. sqlstr=the database query
sub MakeDataFile(fPath, sqlstr)
	dim a, showList, intcount
	set a = fso.createtextfile(fPath)
	set showList = conn.execute(sqlstr)
	for intcount = 0 to showList.fields.count -1
		if intcount <> showList.fields.count-1 then
			a.write """" & showList.fields(intcount).name & ""","
		else
			a.write """" & showList.fields(intcount).name & """"
		end if
	next
	a.writeline ""
	do while not showList.eof
		for intcount = 0 to showList.fields.count - 1
			if intcount <> showList.fields.count - 1 then
				a.write """" & showList.fields(intcount).value & ""","
			else
				a.write """" & showList.fields(intcount).value & """"
			end if
		next
		a.writeline ""
		showList.movenext
	loop
	showList.close
	set showList = nothing
	set a = nothing
end sub
' Call the subprocedure
call MakeDataFile(outputFile,sqlstr)
' Close
set fso = nothing
conn.close
set conn = nothing
if email <> "" then
	dim objMessage
	Set objMessage = CreateObject("CDO.Message")
	objMessage.Subject = subj
	objMessage.From = emailFrom
	objMessage.To = email
	objMessage.TextBody = "There are scheduled works due, please see the attached spreadsheet for details."
	objMessage.AddAttachment outputFile
	objMessage.Configuration.Fields.Item ("http://schemas.microsoft.com/cdo/configuration/sendusing") = 2
	objMessage.Configuration.Fields.Item ("http://schemas.microsoft.com/cdo/configuration/smtpserver") = smtp
	objMessage.Configuration.Fields.Item ("http://schemas.microsoft.com/cdo/configuration/smtpserverport") = smtpPort
objMessage.Configuration.Fields.Update
	objMessage.Send
end if
With the structure you have there the best thing would be to return the row count from your MakeDataFile function, and then stick the email logic in an if block testing it's > 0.
Alternatively, put the email logic in it's own function and call that from within MakeDataFile when not showlist.EOF.
... advise on how I can stop the mail sending if zero rows are returned.
New code below. Wraps everything in
Code:
 if not(showList.eof) then
end if
including creation of the text file.
Code:
option explicit
' Configuration '
dbName = "xxxx"
dbUser = "xxxx"
dbPass = "xxxx"
email = "xxxx"
emailFrom = "xxxx"
  body = "Body text"
  smtp = "xxxx"
  smtpPort = 25
dim fso, conn
		    else
		end if
	    next
	    a.writeline ""
			else
			end if
		next
		a.writeline ""
		showList.movenext
	    loop
	end if
	showList.close
	set a = nothing
end sub
' Close
set fso = nothing
conn.close
set conn = nothing
if email <> "" then
	dim objMessage
	objMessage.Send
end if
