Ok, so im trying to create a backup of some files from a user defined source, to a pre-defined backup folder.
If the file already exists in the backup folder, i dont want it to be backed up, but im struggling to do it.
This is what i have currently, looping through the files in the user defined source folder,checking the dates(That part is fine) and then attempting to check if it exists in the backup folder(cant seem to work out how to do it for each file, in a different directory.
Code:
For Each objfile in objFolder.Files
if DateDiff("d", objfile.datecreated,objfile.datelastmodified) > 0 then
if (Not objFSO.FileExists("C:\backup\" & objfile)) Then
objFSO.CopyFile objfile , "c:\backup\"
Wscript.Echo "Backing up " & Objfile
else if objFSO.FileExists("C:\backup") Then
Wscript.Echo objfile & " Exists, not backing up.."
End if
End if
End if
Next
