vbScript Run Exe with Command Switches
7 Jul 2009
Wiltshire
Hi,
I wonder if anyone can help?
I've got the following vbScript: -
Code:
sub shell(cmd)
	' Run a command as if you were running from the command line#
	dim objShell
	Set objShell = WScript.CreateObject( "WScript.Shell" )
	objShell.Run(cmd)
	Set objShell = Nothing
end sub
shell "C:\Users\Andrew\Downloads\putty\PUTTY.EXE"
This works fine and launches putty.
However, I need to launch it with some command switches and this has got me stumped. Each time I add these I get an error regardless of where I put the quotes and the number.
Has anyone got any idea how I can add the switches?
Thanks & Regards
Just realised I've posted this in the wrong Forum :o
Could someone please move it for me?
Thanks
I'm not sure what you've tried but the obvious way is the correct way:
Code:
shell "C:\Users\Andrew\Downloads\putty\PUTTY.EXE -ssh 127.0.0.1"
Make sure you're giving putty valid arguments.
Thanks for the reply.
I've tried many combinations. Something that might not be helping is that the current switches I'm using on the shortcut to launch it are: -
Code:
C:\Users\Andrew\Downloads\putty\PUTTY.EXE -L 9091:###.78.###.68:9090 -L 5051:###.78.###.68:5050 -load "AAAA" -l Login -pw Password
Possbily the quotes around the saved Session isn't helping?
Regards
Got it!!!!
The answer was to put double quotes around the Session that needed loading.
Code:
C:\Users\Andrew\Downloads\putty\PUTTY.EXE -L 9091:###.78.###.68:9090 -L 5051:###.78.###.68:5050 -load ""AAAA"" -l Login -pw Password
Regards
