VBScript & WMI
16 May 2008
Bristol
Hi,
I'm writing some batch files, one of which starts an application on a list of IPs.
Currently I am using this workaround:
set h=%TIME:~0,2%
set m=%TIME:~3,2%
set s=%TIME:~6,2%
IF [%m%]==[] SET /a m=02 GOTO settime
IF %m%==58 SET /a m=00 GOTO settime
IF %m%==59 SET /a m=01 GOTO settime
IF %m%==60 SET /a m=02 GOTO settime
set /a m=(m+2)
:settime
set time2=%h%:%m%:%s%
FOR /f %%f in (ips.txt) do (
start schtasks /create /tn "run this program" /ru Administrator /rp Password /tr C:\program.exe /s \\%%f /sc once /sd %date% /st %time2%
This schedules a task to run the program 2 minutes in the future and is quite lame. What I would like is a VBS solution which eliminates the 2minute delay but have no experience in VB script..
I found this:
strComputer = InputBox("What computer or IP do you want to use?")
strProg = InputBox("What Program do you want to start?")
Set objWMIService = GetObject _
("winmgmts:\\" & strComputer & "\root\cimv2:Win32_Process")
Error = objWMIService.Create(strProg, null, null, intProcessID)
If Error = 0 Then
Wscript.Echo "Your application was started with a process ID of " _
& intProcessID & "."
Else
Wscript.Echo "Your application could not be started due to error " & _
Error & "."
End If
But it does not account for login credentials. Please could someone advise how to add this functionality?
You seem to be over complicating it but I'm not sure what you are trying to achieve?
What's the need for the 2 min delay and what are you are trying to do with the checking for minutes being nothing/58/59/60? Because I don't think this is doing, or going to do, what you think it is.
If something here is time sensitive then what you seem to be doing here is an odd one as there are two many variables and things that could affect that time.
edit: think I see what the delay is for. didn't realise that the /once had to have a time and date specified. still not sure it works though.
Hi,
As part of a much larger batch file I need to run an .exe file on a list of IPs specified in a txt file without going on to each host individually.
When building it I found sometimes the network lag would cause the task to be created after the %time% value had passed so I added the 2 minute delay. The IF %m%==58 etc is supposed to prevent an invalid %time% value for example 12:61:00 but this has not been tested.
This is my new code (untested) hopefully it will be a bit more efficient:
Dim oFSO : Set oFSO = CreateObject("Scripting.FileSystemObject")
arrLines = Split(oFSO.OpenTextFile("IPs.txt").ReadAll(), VbCrLf)
For i = 0 To UBound(arrLines)
strComputer = arrLines(i)
strProg = "notepad.exe"
Next
