vBulletin Cookie Sharing
14 Feb 2006
Surrey, UK
Hi all,
Right so I'm working on this site which uses a vBulletin forum. And the usernames and passwords used for the forum are also used for the usernames and passwords for the main site.
So
and
use the same usernames and passwords from the same database.
Now here's the problem. When a user logs into the main site, it logs them out of the forums. And vice versa.
Any ideas?
Jon
Just to the main site, ie:
mysite.net.
If it is a naming conflict, what's the best way to sort that out? Seperate cookies for each part, or the same cookie for both?
Jon
Realistically I doubt it's a naming conflict as vB uses a naming convention that's unlikely to be reproduced.
For a quick test try print_r($_COOKIE) using PHP; also temporarily set your site cookies to www.site.com and see if that makes a difference.
