Vbulletin question
26 Dec 2003
Hiya,
Just having a mess around with this, on the forum the usernames are on the top rather than the side like this.
How to do you change it so they are on the left?
Thanks
Another little question.
I want to save the attachments to a folder than a database, it says create a folder, cmod it to 777 and it should work. I do this but when I try and change it to save to the file it says it tried to write a file to it but has failed. Make sure the permissions are correct.
Anyone got any ideas?
