vBulletin question
fiveub's Slave
1 Sep 2007
OcUK HQ
Im part of a gaming community and they want a forum and i offered to use my vB as i dont use it. How can i use in on their website without giving away any personal information??
Thanks.
Can anybody please help me making sure the site owner wont be able to see my files when i upload it to his ftp account?
Christ, give people more than 30 minutes to reply!
People will be less willing to help to see that you're rather impatient.
For the record - I don't know what "personal information" or "my files" you're talking about, so am unable to give advice - maybe others do not either?
Ok, im not worried about security now but im worried about loosing my licence. I want to put my forum on sombody elses site but i can get it took of me..
What are the chances of being caught??
Medium-High. Even higher if you include a link.
You've just told everyone who sees this thread your intentions.
Umm, you want to use a single copy of vB on both sites? That would be a no-no. It's probably just fine to use your existing license on the new domain.
Send them an email and ask.
Also, when/if you do so, you should consider writing in a coherent and parsable fashion. ;)
yes but i havnt told you the website im doing it to?
no, im going to use the licence once on the one site.
vBulletin License said:
# vBulletin license grants you the right to run one instance (a single installation) of the Software on one web server and one web site for each license purchased. Each license may power one instance of the Software on one domain. For each installed instance of the Software, a separate license is required. Modifications to the Software or database to circumvent the one-license-one-board rule are prohibited.
# The Software is licensed only to you. You may not rent, lease, sublicense, sell, assign, pledge, transfer or otherwise dispose of the Software in any form, on a temporary or permanent basis, without the prior written consent of Jelsoft.
It doesn't appear that they would care that you're transferring your forum from one domain to another. Am I understanding you correctly?
